| So, i had spun a rod bearing back in may in my 1990 TT swap 300zx. and the car has been in my driveway since. i pulled the motor, took it all apart in my garage & I have been slowly ordering parts for what i think to be a real nice strong build! I Wanted your honest opinions, i appreciate any feedback as i plan to place this major order within the next 24/48 hours. Here are the parts i have already sitting here! 88mm CP pistons Eagle H-Beam Rods JWT sport 700BB turbos MS manifolds specialty Z 3 inch down Pipes 3 inch Full exhaust 850 cc injectors 300 degree rails with stainless steel braided fuel lines i have ashspec dual pump controller with 2 walbro pumps & i also have an oem pump controller and a low mileage TT pump, not sure which set up to go with) Dual air intake. full 2.5 inch intercooler/intake pipe kit Southbend stage 5 clutch/pressure plate RPS flywheel z1 1 piece driveshaft. Blitz Blow off valves Jun Titanium Valve retainers This is the stuff i am about to order & would really appreciate opinions on. If you recommend something else, or maybe something here really isn't worth the money, let me know!
JWT 500 cams Z1 valve springs Z1 Bronz valve guides full 120k kit with full light weight pulley set full engine gasket/seal set (sticking with OEM head gasket, OEM timing belt) Selin Dual MAF translator kit 3 NA oil squirters 6 oil jet/check valves BDE VTC intake cam gears Z1 exhaust cam gears Z1 oil cooler with stainless steel braided lines Snow performance water/meth injection kit
